dyanne rooney
#1 Posted : Monday, December 12, 2011 12:37:11 PM(UTC)
dyanne rooney
i have a kitchen aid superb model #KGRT607HBL4. the door handle is coming off and is screwed in from the inside. there is no way to access this. it looks like, from the diagram, i have to take the bottom panel off and then go thru layers to get to the handle. the glass in-between the door is dusty and also needs to be cleaned. how do i get to the insides?
ApplianceJunk
#2 Posted : Tuesday, December 13, 2011 10:48:20 AM(UTC)
ApplianceJunk
To clean the glass you will have to remove the door from the oven and take the door apart layer by layer, there is no other way.
To tighten the door handle you maybe able to remove just that top plastic grill, but be careful of the outside glass panel falling out.
dyanne rooney
#3 Posted : Tuesday, December 13, 2011 11:03:12 AM(UTC)
dyanne rooney
how would i take the panel off? no screws and it doesn't pop off.
ApplianceJunk
#4 Posted : Tuesday, December 13, 2011 11:07:01 AM(UTC)
ApplianceJunk
The door will lift off the oven, may have to lock the hinges in the open position.
There are screws holding the door together. Open the door and look at the top corners. Also screws along the bottom trim.
Here is a diagram of the door for your model.
Door and drawer replacement parts for WHIRLPOOL KGRT607HBL4 GAS RANGE | AppliancePartsPros.com
