Ralph Pitsch
#1 Posted : Monday, December 12, 2011 5:22:03 PM(UTC)
Ralph Pitsch
oven top broler and botton bake elements don't come on when you set for bake and set a temp it shows 100 degree and pre heat . same goes for the broler.
ApplianceJunk
#2 Posted : Monday, December 12, 2011 5:39:01 PM(UTC)
ApplianceJunk
I would check the relay board on the back, #28 in this diagram for your model.
Body replacement parts for JENN-AIR SVE47600B RANGE- S/C S/I DDRAFT ELE | AppliancePartsPros.com
Ralph Pitsch
#3 Posted : Monday, December 12, 2011 5:54:49 PM(UTC)
Ralph Pitsch
Is there away to check the relay board
ApplianceJunk
#4 Posted : Monday, December 12, 2011 6:03:33 PM(UTC)
ApplianceJunk
Here is the service manual for your model.
http://appliancejunk.com...wnloads;sa=view;down=385
The service manual has a troubleshooting guide you may find helpful.
I would remove the board and look at the back side for broken solder connections.
Ralph (Refrigerator & Freezer Repair)
by RalphHotpoint 5/14/2009 10:52:06 AM(UTC)
