Shadam
#1 Posted : Tuesday, February 10, 2009 6:01:24 PM(UTC)
Shadam
My Broil Element works, My Bake Element & My Convection Element Does Not Work. Is this a defective timer/electronic control
Thank You
#2 Posted : Wednesday, February 11, 2009 4:50:43 AM(UTC)
Here is your wiring diagram
ftp://ftp.electrolux-na.com/Pr...assomption/318046706.pdf
Yes could be the control board, relay K2 is common to both elements.
Less likely but an ouside possibilty is the relay just to the left of the bake & convection elements in the wiring diagram. But I would expect that one or the other element woud work if the relay was NG.
kairos
#3 Posted : Thursday, April 10, 2014 6:03:49 AM(UTC)
kairos
Denman
can you point me to a dacor service manual for rsd30; it blew a breaker whil convection baking; bake element tested good; thermostat /limitor red reset button will not reset- i push down and it does not reset.
need to get gas stove top off to replace thermostat-help.
finally what else will cause brker to pop then pop again when i try toreset the breaker
thanx so much
kairos
#4 Posted : Friday, April 11, 2014 2:05:15 AM(UTC)
Sorry but I cannot find any info/manual for this unit.
There are a couple Dacor manuals at this site but looks like they are just electrical faults etc.
http://appliancejunk.com/forums/index.php
You will have to join the site and be logged in to be able to download manuals.
Are you trying to reset the thermal cut-off with the power on?
If yes then remove power from the unit before trying to reset it.
I did Google "Dacor RSD30" and did get a few hits on it.
In one the fellow showed an element that was very close to the ovens back wall so could short out.
I am not sure if this unit has a separate element for convection, you may want to check if it does.
kairos
#5 Posted : Friday, April 11, 2014 6:04:59 AM(UTC)
kairos
thanx for your insights - i did join the site- found a couple of dacor docs from forum postings. btw i found that unless that the reset on the high tem thermostat cannot be reset unless it is poped. my seems to be fine. bake elemt is good. there is a broil elemt i will chk. problem with dacor is the design is wacky - no housewife should have to take apanel off toreset a hi-tem thermostat if an oven cleaning pops it. dacor is the yugo of stoves as far as design is concerned.
thanx again
