cybersedona
#1 Posted : Tuesday, February 10, 2009 10:32:09 AM(UTC)
cybersedona
s/n FL057157
Replaced GE Board turns on but now Frig still warm.
cut wire from thermosister as instructed in installation sheet.
did not find where I needed to cut on bottom area,
see pics at:
www.kvid.com/refer/newboard.jpg
www.kvid.com/refer/board-showing-cut-wire.jpg
www.kvid.com/refer/bottom-area-in-question.jpg
www.kvid.com/refer/other-side-not-worked-on.jpg
previously it was clicking for months until stopped clicking, then frig went out.
freezer always worked, but works better now after removing a thin layer of ice in back of freezer.
thanks for any help on this, Greg
#2 Posted : Tuesday, February 10, 2009 8:41:09 PM(UTC)
Greg,
I hope you still have the installation instructions because looks like you cut the wrong wire. Post it.
cybersedona
#3 Posted : Wednesday, February 11, 2009 7:12:16 AM(UTC)
cybersedona
funny, since I posted this the frig works great, getting cool up and down.
here is the link for install instructions. I am still game to get it right if I cut the incorrect wire, appreciate any input.
www.kvid.com/refer/ge-board-install-instructions.pdf
#4 Posted : Wednesday, February 11, 2009 4:31:45 PM(UTC)
Greg,
I believe "thermistor wire in pin 2 of J1 connector" is the white wire on other side of the connector.
cybersedona
#5 Posted : Wednesday, February 11, 2009 5:06:54 PM(UTC)
cybersedona
being that it gets cold really well, I am happy with that, that wire I cut must be for something I cant see yet,
I will try your suggestion and see what happens.
thanks alot.
let you know!
