lznuk
#1 Posted : 17 years ago
lznuk
A year ago I had my top oven repaired because it would not heat up. It was this same time of year so the repairman solder something together instead of ordering a part to get us by. Well it has happened again and I cannot remember the name of the part that I need. The oven will broil and if I turn it to broil first and then turn it off, then turn on to bake I can sometimes get the oven to heat up. It seems to have a short. Any suggestions?
#2 Posted : 17 years ago
Most likely the problem with your oven is a bad relay board.
- The part number for the new relay board AP378359
- Here are the break down diagrams for the Jenn Air oven Model WW30430W
Oven Will not heat to temp. (Oven Repair (including Ranges and Cooktops))
by rtmeek 2 years ago
Frigidaire FEFL79HQA Oven Will Not Heat (Broil or Bake) (Oven Repair (including Ranges and Cooktops))
by Allen_M 3 years ago
Frigidaire - Oven will not heat up but burners work (Oven Repair (including Ranges and Cooktops))
by JohnGuerra 5 years ago
Frigidaire gas oven will not heat (Oven Repair (including Ranges and Cooktops))
by HHG 5 years ago
GE Profile Oven will not heat past 100, broiler works (Oven Repair (including Ranges and Cooktops))
by maribernj 9 years ago
Oven will not heat (Oven Repair (including Ranges and Cooktops))
by couldcareless 9 years ago
by davidwhop 11 years ago
Double Wall Oven will not heat up (Oven Repair (including Ranges and Cooktops))
by jwmingus 11 years ago
Frigidaire Left oven will not heat either element (Oven Repair (including Ranges and Cooktops))
by morang 11 years ago
Thermador sc302t top oven will not heat (Oven Repair (including Ranges and Cooktops))
by bnastasi 12 years ago
Lower and Upper Oven will not heat (Oven Repair (including Ranges and Cooktops))
by Igmike 12 years ago
My Oven will not heat up on bake (Oven Repair (including Ranges and Cooktops))
by missy79 12 years ago
Electrolux dual fuel range oven will not heat (Oven Repair (including Ranges and Cooktops))
by p.andrew 12 years ago
by Pjcibulski 12 years ago
Oven Will Not Heat (Oven Repair (including Ranges and Cooktops))
by badams1214 12 years ago
