ibrahimdd
#1 Posted : 17 years ago
ibrahimdd
Suspect lose connection in the power board, how to open that.
Thanks ..ABE
Michael1
#2 Posted : 17 years ago
Michael1
Thanks ..ABE
Not sure what is wrong with my microwave.The electrical connectionn is working. The machine just stops working. It is about 5 yrs. old. The model is Maytag MMV5100. If it is the fuse, how do you replace the fuse? Thank you,
#3 Posted : 17 years ago
Rank:: Advanced Member
ABE
In order to get the access to the control panel you have to remove the top grill first.
#4 Posted : 17 years ago
Michael1
What did you mean "stops working"?
What it does and what it does not?
The model number you provided is incomplete.
Please, post the new information as a new thread.
ibrahimdd
#5 Posted : 17 years ago
ibrahimdd
Hi Gene...It is GE, mod. JVM 186 1SD 002. Took out all the covers required. The power board has 6 fingers ---1 stiiking in thrue the frame. The board seems it suppose to slide out upward, could not.
Where I can get service manual. No print inside. No screws holding the board....Thanks ABE ...707 586 0543
ibrahimdd
#6 Posted : 17 years ago
ibrahimdd
Gene, in 50 years, I never saw worse than this micro.,I tried again today, it sound unbeateble. If you don't see it you wan't beleive me. I could see 3 screws one on top by the jumper support. and two on the bottom (you have to turn it upside down) to see it, and these 3 screws are put from inside the board.
so again how to open the board ?? ABE
