2 Pages12>
kthrn
#1 Posted : 17 years ago
kthrn
Please help! I accidentally removed my oven door while moving the oven to paint and now I cannot get it back on. I have tried prying the hinges open and everytime I think it is on it snaps back out of place. I do not know what to try next. Nothing has broken as far as I can tell. A reply would be greatly appreciated. Thank you.:confused:
#2 Posted : 17 years ago
Hi kthrn
In order to provide you with most accurate advise I need the complete model number of your oven.
Cherad
#3 Posted : 17 years ago
Cherad
I'm glad I'm not the only person who dislodged the oven door to paint in the kitchen.
I have a Whirlpool Super Capacity 465 range/oven and can't seem to get the left side of the door back on it's hinges. It sounds like the exact problem. Any ideas on replacing? Thank you in advance
Brad
#4 Posted : 17 years ago
Hi Cherad
In order to provide the most accurate advise I need the complete model number of your oven.
Please, post it as a new thread.
mattsegawa
#5 Posted : 17 years ago
mattsegawa
I did the same thing.
Model number SF395LEEQ.
I just ordered a spark electrode from you guys as well.
thank you.
matt
#6 Posted : 17 years ago
Hi mattsegawa
The instructions how to reinstall the door you can find in a "Use and care" manual on the page 35.
Good luck.
mattsegawa
#7 Posted : 17 years ago
mattsegawa
Thanks for the reply. I checked out the manual. They show a different bracket than what I have. There is no pinhole in mine. The brackets keep springing back at me. I've tried to lodge things in there to hold it, but it just doesn't want to hold enough to be give me a chance to install the door.
#8 Posted : 17 years ago
It suppose to be a hole. Push it down as much as possible.
toastcoastie
#9 Posted : 17 years ago
toastcoastie
I have same problem, model no. SF360BEEZ0, as Mattsegawa and others. As he stated owner inst's show a hinge hanger that does no match the installed part--ie there is NO pin hole. Thus no way to hold the hinge open. I've checked several times to ensure I didn't miss it. Even thought about drilling a hole, but shied away from it as I didn't want to do something I'd regret. Any help from Gene or other threads would be appreciated
#10 Posted : 17 years ago
I've never seen or heard about a missing hole for the door removal pin on a door hinge.
Here are the break down diagrams for the Whirlpool range Model SF360BEEZ0.
Oven door help? (Oven Repair (including Ranges and Cooktops))
by riki 9 years ago
Oven door help (Oven Repair (including Ranges and Cooktops))
by labordec 15 years ago
Whirlpool Oven Door Help (Oven Repair (including Ranges and Cooktops))
by RitaCStanley@aol.com 16 years ago
oven door help (Oven Repair (including Ranges and Cooktops))
by marcue 16 years ago
2 Pages12>
