The leak I was having was from the tub seal. When the tub was agitating during the wash cycle nothing would leak. During the spin, it would leak a little. Then it might leak during the wash cycle if the tub stopped in the right spot after spin cycle.
-Dave
Dave,
What is the complete model number of the washer?
Gene. I'm all done now. The model was LAT2300AA and it is much easier to fix than the other models. The outer tub does not have to be removed. I found this out too late.
Good for you. We are glad you were able to fix it.
