2 Pages<12
vole
#11 Posted : Monday, February 9, 2009 8:10:37 PM(UTC)
vole
The leak I was having was from the tub seal. When the tub was agitating during the wash cycle nothing would leak. During the spin, it would leak a little. Then it might leak during the wash cycle if the tub stopped in the right spot after spin cycle.
-Dave
#12 Posted : Monday, February 9, 2009 8:15:35 PM(UTC)
Dave,
What is the complete model number of the washer?
vole
#13 Posted : Monday, February 9, 2009 8:28:34 PM(UTC)
vole
Dave,
I'm all done now. The model was LAT2300AA and it is much easier to fix than the other models. The outer tub does not have to be removed. I found this out too late.
#14 Posted : Monday, February 9, 2009 8:41:19 PM(UTC)
Good for you. We are glad you were able to fix it.
Which part should I replace for leaking Maytag washer (Washer Repair)
by allofakind 3/5/2015 6:17:16 AM(UTC)
Water Leaking Maytag Washer Below the tub (Washer Repair)
by bhasho 4/19/2012 2:43:29 PM(UTC)
leaking maytag washer (Washer Repair)
by pageroc 1/13/2009 12:34:17 PM(UTC)
2 Pages<12
