handy148
#1 Posted : Monday, February 9, 2009 6:26:00 PM(UTC)
handy148
Dryer still run but no heat. Check top and bottom heat element both OK. Replace the thermal fuse with a new one. Inspected the heating coil and it Ok. Reset breaker, started dryer up and still no heat.
#2 Posted : Tuesday, February 10, 2009 2:55:33 AM(UTC)
Here are your parts, includes a wiring diagram
Model ADE7000AYW
If the heating element is OK then it will be one of the thermostats OR the heat selector switch OR the timer OR the centrifugal switch OR the power.
All the above except the centrifugal switch can be checked with a meter.
The thermal fuse would have shut down the motor on this unit.
I would suggest you purchase a meter. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long.
gas dryer stop heating (Dryer Repair)
by stewart 1/7/2009 5:12:45 AM(UTC)
