My dryer stops heating after about ten mins.The vent is clear and blowing with good pressure.I replaced the igniter and it's still the same. It has 2 thermostats should I replace them both or can you tell which one is bad??
The first thing I would check is the thermal fuse. What is the complete model number of the dryer?
the model #is rgx4643jq0 and if it is the thermal fuse is there a easy way to check it?
