3 Pages123>
dlscrib
#1 Posted : Monday, February 9, 2009 4:20:55 PM(UTC)
dlscrib
The sprayer arms will not spin. I have cleaned out the arms and they spin freely by hand. You can see that the water is coming out, it is just not spinning anymore. Please help.
#2 Posted : Tuesday, February 10, 2009 5:29:25 PM(UTC)
What is the complete model number of the dishwasher?
dlscrib
#3 Posted : Wednesday, February 11, 2009 12:12:23 PM(UTC)
dlscrib
model # MDB4100AWW
Jetclean dishwaher-quiet pack
#4 Posted : Wednesday, February 11, 2009 4:37:17 PM(UTC)
Most likely the problem is a clogged filter (#6 on the diagram) and a clogged rinse arm assembly (#7 on the diagram).
You have to remove the lower spray arm and the pump cover to access these parts.
dlscrib
#5 Posted : Wednesday, February 11, 2009 4:49:48 PM(UTC)
dlscrib
Does this filter need to be replaced or just cleaned? I have cleaned it in the past but have never replaced it.
Thank You for your help.
#6 Posted : Wednesday, February 11, 2009 4:55:57 PM(UTC)
You do not have to replace it if it's not damaged and is completely open. Soak in white vinegar and clean with a soft brush.
dlscrib
#7 Posted : Thursday, February 12, 2009 4:49:50 PM(UTC)
dlscrib
Thanks for the info. I did that tonight and it is working great. Thanks again
#8 Posted : Thursday, February 12, 2009 5:48:00 PM(UTC)
You are welcome. I'm glad it did work for you.
undofkirk
#9 Posted : Monday, March 9, 2009 6:35:16 PM(UTC)
undofkirk
Is it necessary to remove the filter (#6) in order to effectively clean it? I am trying to remove the screw(#12) but the impeller assy (#14) just spins and I am unable to loosen the screw. Is there something I need to do in order to remove the screw? Thanks in advance for any/all help.
#10 Posted : Monday, March 9, 2009 6:41:14 PM(UTC)
You do not have to remove this screw. You went too deep. The filter (#6) just pulls up.
Guest (5)
3 Pages123>
