Originally Posted by: DisneyMommy  Thanks, Joe! I appreciate the reply! I was hoping to order from you as your price on the clock/timer was in line with Sears and shipping was super fast. Unfortunately, you are about $30 more expensive than Sears for this exact item. Thanks again for you help! DisneyMommy, You're quite welcome, it's a pleasure to assist. AppliancePartsPros does have a price matching policy. You may want to contact the Customer Service Team at 1- (877)-477-7278, if you haven't orderred your part yet. Either way, drop us a line when you're through, and let us know how everything went. :) :) :)
With the symptoms my oven has I'm thinking I also need to just replace the EOC... There was a pop, then F1 code and keyboard flashing/doesn't work (just stops beeping temporariliy for 30 or 60 seconds if I hit any button)... and oven locked and won't heat now (burners still work though)... If I replace the EOC that should do it it seems... correct?
What is the complete model number of the oven?
My model number is FEF366CCB, Frigidaire Classic Series oven.
Yes, your diagnosis is correct. It is recommended to replace the overlay together with the EOC because it's self adhesive. - The EOC Part number: AP3561834
