djjd
#1 Posted : Sunday, February 8, 2009 7:15:05 PM(UTC)
djjd
Hello! I have a Whirlpool LTE5243DQ thin twin stackable washer/dryer. The washer is making a very loud rubbing or grating sound during agitation. The sound is not present during spin. Any ideas for replacement parts I could try to fix the problem? Many thanks.
#2 Posted : Monday, February 9, 2009 2:51:16 AM(UTC)
You might have busted agitator paws in the upper section of the agitator. Just verify by turning the upper section. If bad, remove the 7/16 nut and pull out the agitator. Stand on the lower section of the agitator and yank off the top section.
djjd
#3 Posted : Monday, February 9, 2009 9:33:21 AM(UTC)
djjd
Thanks for the reply. I don't get any noise from manually moving the agitator and the paws that engage the removable portion seem to be in good shape. The sound is like a sawing that goes with the action of the agitator. What should I do next to troubleshoot?
#4 Posted : Tuesday, February 10, 2009 12:29:49 AM(UTC)
Pull out the agitator and check it, might have something stuck in there.
djjd
#5 Posted : Thursday, February 12, 2009 7:47:08 PM(UTC)
djjd
Rich thanks for the continued advice. I pulled the agitator completely and ran the agitation cycle of the wash. The sound is still present. It sounds like a power drill on/off coming from inside the cabinet. I don't know how to get in there to look (and listen) around. Any advice?
#6 Posted : Friday, February 13, 2009 12:26:09 AM(UTC)
Remove the screws from the panel above the washer door and remove each riply spring clip. Lower washer outer panel will slide right out. Washer should agitate without the lid switch.
djjd
#7 Posted : Monday, February 16, 2009 8:14:51 PM(UTC)
djjd
Rich, thanks for all your help. I would not have made it this far without it. It looks like I have a broken spring in the rear left hand corner which tilts the tub and causes the motor to come in contact with the washer base, and thus noise!
So, I see the springs for sale on the website. Do I need to pull the tub to do the replacement or can I swap out the springs in place? If I need to pull the tub, is the only tool I need the spanner wrench?
Thanks!
djjd attached the following image(s):
#8 Posted : Tuesday, February 17, 2009 12:34:22 AM(UTC)
Looks like there is a screw under the bottom frame to take out, then brace the bottom of the transmission with wood to pull the spring out.
Let us know how you make out with this.
Whirlpool WRF535SWHZ07 Won't Program Control Board (Refrigerator & Freezer Repair)
by Guest 7/5/2024 1:43:28 AM(UTC)
WRF989SDAM03 Whirlpool fridge making ice very slowly (Refrigerator & Freezer Repair)
by BlueWRXPride 6/20/2024 5:24:45 PM(UTC)
Whirlpool dryer light (Dryer Repair)
by Guest 6/19/2024 12:27:19 PM(UTC)
Whirlpool fridge WRF560SFYM02 (Refrigerator & Freezer Repair)
by Guest 6/15/2024 5:02:08 AM(UTC)
Whirlpool Oven/Microwave combo E1 F2 (Oven Repair (including Ranges and Cooktops))
by MalcolmR 6/12/2024 10:02:00 AM(UTC)
Whirlpool cont. clean stove SF330 PERN6 (Oven Repair (including Ranges and Cooktops))
by bruce.kolozy@att.net 6/10/2024 2:55:08 PM(UTC)
Whirlpool Gold Accubake Oven/Microwave (Oven Repair (including Ranges and Cooktops))
by Guest 6/10/2024 10:21:28 AM(UTC)
Whirlpool wtw500dw1 won't fill (Washer Repair)
by Guest 6/9/2024 4:14:40 PM(UTC)
Whirlpool duet washer front load (Washer Repair)
by Guest 6/3/2024 9:57:09 AM(UTC)
Whirlpool LA5700XTN0 won't agitate (Washer Repair)
by Kyou 6/2/2024 5:13:20 PM(UTC)
Whirlpool Flame Cuts off After 5-10 seconds (Dryer Repair)
by Guest 6/1/2024 8:00:29 AM(UTC)
Freezer Help from Whirlpool Unit (Refrigerator & Freezer Repair)
by Guest 5/15/2024 5:37:40 AM(UTC)
Whirlpool Duet Sport wgd8300sw0 - drying time takes forever (Dryer Repair)
by mattyP4321 5/14/2024 8:34:23 AM(UTC)
Whirlpool Fridge odor (Refrigerator & Freezer Repair)
by Guest 5/14/2024 4:46:42 AM(UTC)
whirlpool washer will only agitate on gentle (Washer Repair)
by marycwells@gmail.com 5/8/2024 7:09:34 PM(UTC)
