Sticks in wash cycle right before rinse with heating delay light on. Move the knob manually to rinse it will complete cycle. Already put new timer in and have same problem.
The cause of the problem could be very cold incoming water (much bellow recommended by the manufacturer 120°F) or something wrong in the heating circuit (the heater or the thermostat under the dishwasher). Here are the break down diagrams for the Maytag dishwasher Model DWU7400AAXGene.
Opened the door when cycle stalls, water is very hot.
Rank:: Advanced Member
You have been a member since:: 2/29/2008(UTC) Posts: 19,638
THIS FORUM IS DEAD!!!!!!! |
You have been a member since:: 3/10/2009(UTC) Posts: 4
I mhaving same problem with my dishwasher/ same model also.
Did you do anything to diagnose the problem? Did you follow the instructions from the previous replies?
It completes cycle with temp sensor off
mine also completes cycle with temp. sensor off.
Most likely the problem is a bad boost thermostat (#15 on the diagram), but here is a small chance for the control board to be bad too. In order to provide the correct part number for the boost thermostat we need the serial number of the dishwashers. Gene.
