richardalan93
#1 Posted : Monday, November 28, 2011 4:24:29 PM(UTC)
richardalan93
Panel blew and I ordered a replacement from you guys (Order Summary #2121206 ) and installed no problem (per this thread http://forum.appliancepartspros...oven-lost-all-power.html). The proble now is the oven will heat to a set temp but it will not hold that temp. The oven cools down about 70 degrees on convection and has a range of 30 degrees on regular bake. I have to turn the oven off and then back on in order to get it to heat again. I tested the temp sensor and I measure 1094 Ohms. Can I test the panel to see if it is defective?
richardalan93
#2 Posted : Wednesday, November 30, 2011 7:54:15 AM(UTC)
richardalan93
take it to the top.
richardalan93
#3 Posted : Monday, December 5, 2011 4:52:09 PM(UTC)
richardalan93
Still no answer....Please help.
ApplianceJunk
#4 Posted : Monday, December 5, 2011 5:08:23 PM(UTC)
ApplianceJunk
That really seems like a strange problem.
Just looking at the tech sheet and there is not much to this oven. The oven elements get power from the control. The oven control never displays any F error codes?
Here is a copy of the tech sheet if you would like to take a look yourself.
File Attachment(s):
Tech Sheet - 4451876.pdf (402kb) downloaded 7 time(s).
richardalan93
#5 Posted : Tuesday, December 6, 2011 5:59:04 AM(UTC)
richardalan93
No error code at all and now I've replaced the control board twice. Could one of the elements be out (like the bottom one or the one in the convection fan)? I can see that the top one works. What about the transformers? I was told to check the primary and secondary transformer windings for continuitity which I can do, just need a little bit more detail as to the steps.
One thing I have noticed is the temperature swing is much greater in the convection mode.
