Riggo
#1 Posted : Thursday, December 1, 2011 10:43:02 AM(UTC)
Riggo
Frigidaire Afinity Model AE06000ES2 electric dryer stops immediately after start button is pressed. Drum turns ~1/8 rotation in heat mode then stops, but does spin in "air fluff/no heat" mode.
ApplianceJunk
#2 Posted : Saturday, December 3, 2011 5:18:40 AM(UTC)
ApplianceJunk
I would check the block were the dryer cord connects to the back of the dryer and make sure the screws are tight, unplug it first. ;)
Could also be a timer problem.
Riggo
#3 Posted : Monday, December 5, 2011 10:20:24 AM(UTC)
Riggo
screws are tight. Took dryer apart and tested the 2 thermostats, they are funcitoning properly. Had them verified by a local parts store.
ApplianceJunk
#4 Posted : Monday, December 5, 2011 10:23:13 AM(UTC)
ApplianceJunk
Could be a problem with the motor. Can you spin the motor by hand?
Riggo
#5 Posted : Wednesday, December 21, 2011 7:20:04 PM(UTC)
Riggo
yeah, able to turn drum and drum turns on no heat mode
