Frigidaire Afinity Model AE06000ES2 electric dryer stops immediately after start button is pressed. Drum turns ~1/8 rotation in heat mode then stops, but does spin in "air fluff/no heat" mode.
I would check the block were the dryer cord connects to the back of the dryer and make sure the screws are tight, unplug it first. ;)
Could also be a timer problem.
Originally Posted by: ApplianceJunk I would check the block were the dryer cord connects to the back of the dryer and make sure the screws are tight, unplug it first. ;)
Could also be a timer problem. screws are tight. Took dryer apart and tested the 2 thermostats, they are funcitoning properly. Had them verified by a local parts store.
Could be a problem with the motor. Can you spin the motor by hand?
yeah, able to turn drum and drum turns on no heat mode
