2 Pages12>
swadmiral
#1 Posted : Saturday, December 3, 2011 7:09:04 AM(UTC)
swadmiral
i just replaced the door latch assembly on the dishwasher because the door wouldn't close all of the way, and now there is no water in the dishwasher. what did i do wrong!!
ApplianceJunk
#2 Posted : Saturday, December 3, 2011 7:32:34 AM(UTC)
ApplianceJunk
Sounds like a problem with the door switch, double check it to make sure it mounted and wired correctly.
May sound silly, but did you re connect the power to the dishwasher after replacing the switch?
swadmiral
#3 Posted : Saturday, December 3, 2011 7:36:36 AM(UTC)
swadmiral
yes, i reset the breaker. how do i make sure that it's wired correctly? thank you
ApplianceJunk
#4 Posted : Saturday, December 3, 2011 7:39:23 AM(UTC)
ApplianceJunk
When you said that you replaced the door latch I was thinking you were talking about this part.
WHIRLPOOL Door Latch Assembly, part number: AP4113223
If so there are two door switches on it, did you take note how the wires were connect before you removed them?
If so check check your notes and make sure it's wired correctly.
swadmiral
#5 Posted : Saturday, December 3, 2011 7:53:33 AM(UTC)
swadmiral
yes, i took mental notes on where those went but maybe i remembered wrong (it happens sometimes to me). i'm going to try and reverse the wires and see what happens. usually there are instructions that come with the parts but not this time. thank you for your help. i'll let you know how this rewiring goes!
ApplianceJunk
#6 Posted : Saturday, December 3, 2011 7:57:35 AM(UTC)
ApplianceJunk
If you remove the toe plate at the bottom of the dishwasher you may find a tech sheet that would include the wiring diagram.
swadmiral
#7 Posted : Saturday, December 3, 2011 8:13:46 AM(UTC)
swadmiral
yep, but it's too technical for me...
i switched the wires but it still doesn't work.
ApplianceJunk
#8 Posted : Saturday, December 3, 2011 8:29:45 AM(UTC)
ApplianceJunk
Did the dishwasher run before you decided to replace the door switch?
swadmiral
#9 Posted : Saturday, December 3, 2011 8:38:29 AM(UTC)
swadmiral
yes but we had to tape the door shut
swadmiral
#10 Posted : Saturday, December 3, 2011 8:59:47 AM(UTC)
swadmiral
ok. so i took out the new switches that came with the new door latch and put the old switches in the new latch and IT WORKS!! thank you so much for your help. you do a wonderful service. stephen
Guest (10)
dishwasher not filling with water...already changed water inlet valve (Dishwasher Repair)
by jbonez 5/25/2021 5:32:22 PM(UTC)
GE Dishwasher not filling with water (Dishwasher Repair)
by shawnkocher508 10/31/2016 12:12:32 PM(UTC)
KitchenAid Dishwasher not filling with water (Dishwasher Repair)
by njallison@juno.com 7/16/2015 5:58:31 PM(UTC)
Maytag Dishwasher not filling with water (Dishwasher Repair)
by icemanbryan 8/15/2013 5:43:03 PM(UTC)
by rcb 12/10/2012 2:57:55 PM(UTC)
by drs2578 4/19/2011 5:22:56 PM(UTC)
Bosch Dishwasher not filling with water (Dishwasher Repair)
by RSC007 10/21/2010 4:56:48 PM(UTC)
by durl68 2/2/2010 2:30:22 PM(UTC)
Bosch dishwasher not filling with water (Dishwasher Repair)
by rritter 12/12/2007 6:32:25 PM(UTC)
2 Pages12>
