dryer not heating up fuse is not tripped and gas is being fed. Maybe pilot light?:confused:
When I looked up your model number I found this model does not have a pilot light. It has a ignitor.
If you can't see the glow of the ignitor coming on I would check to see if there was voltage to the ignitor and if there was voltage then I would go ahead and replace the ignitor.
