10 Pages«<78910>
smith1326
#81 Posted : Wednesday, October 26, 2011 5:20:38 PM(UTC)
smith1326
which side faces the oven burner.
#82 Posted : Friday, October 28, 2011 3:25:08 PM(UTC)
There are no options. You can install it only one way.
Admin / APP Team
#83 Posted : Friday, November 18, 2011 4:22:55 PM(UTC)
Admin / APP Team
Rank: Administration
Groups:
We now have a step-by-step video showing how to replace an oven igniter (either flat or round):
Part number: AP4012072
shirlt
#84 Posted : Friday, December 2, 2011 8:08:23 AM(UTC)
shirlt
After cleaning cycle I have always gotten a F code. I have only used the clean 3 times on this range. This time I got the F2 which says (for an unknown reason the oven temp has exceeded the preset threshold. The only other code we got was fc, & it says this cod means that component has failed somewhere in door lock circuit. Even after unplugging for a long time we either had lock just clicking off & on constantly, or would not unlock. It is like the lock function is shorting out. Do you have any suggestions what this could be?
#85 Posted : Saturday, December 3, 2011 9:07:57 PM(UTC)
Sounds like the problem is a bad oven control board, but there is a small chance for the door latch to be bad as well. Unfortunately there are no instrumental tests in such situation. I would replace the control board first.
- The control board Part number: AP3957552
homer2
#86 Posted : Tuesday, May 8, 2012 11:04:50 AM(UTC)
homer2
I have a Maytag MGR4451BDW Stove.
Only 2 of the 4 ignigtors work. I can move the burners around and they will spark in different spots.
I checked and there are 3 ignitors with the same part number and one with a different part number. The only difference I see is the one has a wider spade than the rest.
What would be the reason?
If I replace all the ignitors, will that fix my problem?
Homer
selder
#87 Posted : Monday, June 11, 2012 12:48:50 PM(UTC)
selder
Ok so I've replaced the oven igniter, it worked so I put everything back together. Now it won't even come on. Seems to me like there would be a short or something somewhere but I don't know where to start. any help would be appreciated.
#88 Posted : Monday, June 11, 2012 2:49:50 PM(UTC)
What was the original problem?
What is the complete model number of the oven?
selder
#89 Posted : Friday, June 15, 2012 7:38:14 AM(UTC)
selder
sf377pegw1 its a whirlpool gas range. Oven won't light, but broiler and burners still do.
#90 Posted : Saturday, June 16, 2012 5:13:58 PM(UTC)
Check for 120 VAC to the igniter while the control calls for Bake. Post the results.
Guest (4)
10 Pages«<78910>
