geomaciii
#1 Posted : Monday, November 28, 2011 6:48:53 PM(UTC)
geomaciii
I have moved the timer around to the 3 different settings to the spin/drain cycle and get nothing. The drive belt is good (2 yo)
Read more: http://forum.appliancepartspros...-spin.html#ixzz1f3wfIZfh
http://forum.appliancepartspros.com
sidfink43
#2 Posted : Wednesday, November 30, 2011 5:26:23 PM(UTC)
sidfink43
See if the motor is turning when it is supposed to be spinning. If it is the transmission probably has a problem. If not, check the wiring from the timer to the motor and try replacing the timer.
washer won't drain/spin (Dishwasher Repair)
by geomaciii 11/28/2011 4:33:45 PM(UTC)
Frigidaire washer won't drain/spin (Washer Repair)
by christylowe 12/6/2009 5:58:28 AM(UTC)
Washer won't drain/spin in rinse cylce (Washer Repair)
by jimII 1/14/2008 7:10:52 AM(UTC)
