Prohet7
#1 Posted : Friday, November 25, 2011 7:25:14 AM(UTC)
Prohet7
when my refrigerator turns of it makes a loud clunking noise, please help?
#2 Posted : Friday, November 25, 2011 8:05:57 AM(UTC)
I cannot find any info on the given model number.
A loud bang/clunk when the compressor shuts off usually means the compressor is on it's last legs. There are mechanical problems inside the compressor.
It may last days or months. There is no way to tell but the unit cannot be trusted any more. When it finally fails you could loose several hundreds of dollars in food so I would turn it into a beer fridge if you have a need for such a thing.
I would check it just to be sure that it is not due to a bad compressor mount (rubber feet/washers under the compressor mounting bolts).
Replacing a compressor will be an expensive repair as you need a pro. Often it makes more sense to invest those dollars in a new unit.
Check your warranty as many units have a longer warranty on the sealed system/compressor.
Prohet7
#3 Posted : Saturday, November 26, 2011 8:17:16 AM(UTC)
Prohet7
Thanks demand just as i figured pray it last another yea
r. Bless you!
Sub-Zero new model makes loud noise (Refrigerator & Freezer Repair)
by Guest 5/3/2024 7:49:55 PM(UTC)
Loud noise at start of spin cycle that stops once at high RPM (Washer Repair)
by tollisal 1/28/2023 8:48:50 AM(UTC)
LG LG WM2016CW Side load washing machine loud noise (clip included) (Washer Repair)
by Guest 9/29/2022 5:53:08 PM(UTC)
GE washer: loud noise when spinning (Dishwasher Repair)
by Guest 8/7/2022 12:54:21 PM(UTC)
GE Refrigerator #GSHS5KGXBCSS No water and loud noise after filter replacement (Refrigerator & Freezer Repair)
by Guest 8/26/2021 6:48:33 PM(UTC)
MAV7600AWW makes loud noise during spin cylce (Washer Repair)
by Guest 6/14/2021 6:09:42 PM(UTC)
Whirlpool Cabrio Platinum - Loud Noise at Start (Washer Repair)
by jlucenius 1/19/2021 2:05:51 PM(UTC)
Loud noise during anti static cycle on my Frigidaire dryer (Dryer Repair)
by GR8TSCT99 5/1/2019 4:40:02 AM(UTC)
loud noise during the spin cycle (Washer Repair)
by cznlzq 4/24/2019 6:30:35 AM(UTC)
LG Gas Dryer - loud noise, now won’t come on (Dryer Repair)
by Benay 3/4/2019 7:20:40 AM(UTC)
Water Dispenser Makes loud noise now (Refrigerator & Freezer Repair)
by zamboknee 1/5/2018 12:45:09 PM(UTC)
Maytag Centennial single loud noise when spin ends (Washer Repair)
by BigRenwick 2/27/2017 5:41:58 PM(UTC)
Horrific Loud Noise - Can't Find Solution (Washer Repair)
by PetraG310 11/14/2016 12:03:02 PM(UTC)
GE Washer Loud Noise (Washer Repair)
by rock324 1/29/2016 12:05:58 PM(UTC)
Kenmore washer 70 series loud noise issues (Washer Repair)
by wagnerplp 1/26/2016 9:20:19 AM(UTC)
