catjay
#1 Posted : Monday, February 2, 2009 8:31:32 AM(UTC)
catjay
I have a whirlpool dishwasher that stopped working today.I have power going to the control panel and the door switch seems to be working but nothing works.None of the buttons on the front work.The lights did flicker once but that was it.Any advice?
ineedhelp123
#2 Posted : Monday, February 2, 2009 10:18:09 AM(UTC)
ineedhelp123
i have the problem of the dish water is spitting water in to the basement and the spray nozzle is not getting enough pressure to spin it. i ask there is a pressure ring under it is it suppose to be hole or is it suppose to have a common i shaped crack in it
#3 Posted : Monday, February 2, 2009 6:27:35 PM(UTC)
catjay,
Did you check the thermal fuse (#4 on the break down diagram) for continuity?
#4 Posted : Monday, February 2, 2009 6:28:32 PM(UTC)
ineedhelp123,
What is the complete model number of the dishwasher?
gene.
#5 Posted : Tuesday, February 3, 2009 2:31:29 AM(UTC)
catjay
Here is a tech sheet for your unit
https://www.servicematters.com/d...0Sheet%20-%208535431.pdf
Whirlpool dishwasher WDT780SAEM1 (Dishwasher Repair)
by Guest 6/15/2023 1:10:41 PM(UTC)
Whirlpool Dishwasher Won't Advance Cycle (Dishwasher Repair)
by amappliancewi 3/28/2023 12:02:52 PM(UTC)
Whirlpool Dishwasher not draining at end of cycle-intermittently (Dishwasher Repair)
by Floyd Pinkerton 9/28/2022 11:07:32 AM(UTC)
Whirlpool Dishwasher Wiring (Dishwasher Repair)
by Chitreano 6/21/2022 9:47:55 AM(UTC)
Whirlpool Dishwasher WDF520PADM7 Sanitized light blinking ***SOLVED (Dishwasher Repair)
by NC_OldGuy 5/20/2022 10:34:10 AM(UTC)
Whirlpool Dishwasher Won't Drain Completely, I hear Pump Running... (Dishwasher Repair)
by Guest 4/18/2022 5:39:50 PM(UTC)
Whirlpool Dishwasher: next steps to diagnose upper arms not spraying (Dishwasher Repair)
by erotenberg 1/9/2022 11:00:38 PM(UTC)
Whirlpool dishwasher not draining with diagnostics code 6-4 (Dishwasher Repair)
by dcelbert 12/28/2021 11:04:45 AM(UTC)
Whirlpool dishwasher drain issue (Dishwasher Repair)
by Bostomw 11/11/2021 3:54:47 PM(UTC)
Whirlpool dishwasher (WDF520PADM3) Cycle lights don't lit up (Dishwasher Repair)
by gowin09 6/13/2021 1:48:33 PM(UTC)
Whirlpool dishwasher door leak (Dishwasher Repair)
by Guest 5/26/2021 9:40:52 AM(UTC)
Whirlpool dishwasher - Replacing soap dispenser door? (Dishwasher Repair)
by NJGuy 5/17/2021 10:55:47 AM(UTC)
Whirlpool Dishwasher Intermittent Operation (Dishwasher Repair)
by Craigius757 3/12/2021 9:19:22 AM(UTC)
whirlpool Dishwasher WDT750SAHZ0 Leaking (Dishwasher Repair)
by Deanomich 10/15/2020 7:27:19 PM(UTC)
Whirlpool dishwasher shudders between wash/rinse and drain (Dishwasher Repair)
by aeb58DIY 7/6/2020 3:17:09 PM(UTC)
