momguyvr
#1 Posted : Thursday, January 29, 2009 4:32:37 PM(UTC)
momguyvr
My dryer was screeching for a minute then it shut off. Now when I try to start it it just sort of hums! HELP!
breezy9237
#2 Posted : Thursday, January 29, 2009 4:58:11 PM(UTC)
breezy9237
Sounds like the belt has either slipped or broke.
momguyvr
#3 Posted : Saturday, January 31, 2009 3:56:13 AM(UTC)
momguyvr
I just replaced the belt. Any other ideas?
#4 Posted : Saturday, January 31, 2009 7:26:54 AM(UTC)
Why did you replace the belt?
Was it for this same problem?
Try turning the drum by hand. It should turn relatively easily.
If it does.
This may take two people.
Open the door and hold the door switch closed.
Push the start switch and rotate the drum by hand in the correct direction.
Watch your knuckles in case it starts up.
If it does start rotating the probability is high that your motor needs replacing.
momguyvr
#5 Posted : Saturday, January 31, 2009 3:36:06 PM(UTC)
momguyvr
If it does.
It was squeeling and I found the glides were shot and the belt was a little frayed ( drum was rubbing because of this). So I replaced both, but now, just humming. I will try what you suggested and let you know the results. Thanks much.
Guest (4)
