mightypasta
#1 Posted : Monday, November 21, 2011 8:55:22 AM(UTC)
mightypasta
Old Maytag washer is leaking water in to the tub while not running. If left it will fill up over a couple days.
I think we may need to replace the water inlet valve but are not sure.
Would appreciate any help and quick! Thank you!:)
magician59
#2 Posted : Monday, November 21, 2011 9:12:30 AM(UTC)
magician59
Try this: Unplug the machine. Watch it over a period of time. If you come back and see water in the tub, chances are excelent that you need to replace the water inlet valve.
These valves are electric-solenoid controlled. If debris gets through the inlet screening and fouls the valve, it won't seat completely, and water will be allowed to seep through. They are not servicable; they must be replaced when they get to this stage.
Part number: AP4026239
mightypasta
#3 Posted : Monday, November 21, 2011 9:15:05 AM(UTC)
mightypasta
Thanks!
Serial number isA0351456MH
is this part the right fit?
magician59
#4 Posted : Monday, November 21, 2011 9:29:40 AM(UTC)
magician59
It is the only one listed with this model.
