kimgs56
#1 Posted : Wednesday, January 28, 2009 11:33:41 AM(UTC)
kimgs56
ordered middle spray arm and supply tube kit...when you put the split ring onto the supply tube, it doesn't fit all the way into the hole in the spray arm...are you supposed to jam it in there? the notice with the parts said to use all parts..help!:confused:
#2 Posted : Thursday, January 29, 2009 4:42:09 PM(UTC)
If the part you called "split ring" is the bearing ring (#1 on the break down diagram) then it should be connected to the supply tube as shown on the diagram. The spray arm should spin free after everything assembled.
kimgs56
#3 Posted : Friday, January 30, 2009 5:42:22 AM(UTC)
kimgs56
yes, thank you, that's the part, however it doesn't "lock" all the way down into the spray arm....is that how it's supposed to be?
#4 Posted : Friday, January 30, 2009 7:47:54 PM(UTC)
...The spray arm should spin free after everything assembled...
This is the most important.
