solson
#1 Posted : Thursday, January 29, 2009 6:22:41 AM(UTC)
solson
The cycle monitor light on the front panel goes thru every cycle. The water fills on the and does not drain. There is no additional action or noise inside? When I open the door after the dry cycle the water is in the bottom and the soap holder is open with the soap in it.
#2 Posted : Thursday, January 29, 2009 8:54:22 PM(UTC)
Sounds like the pump is not working. Remove the toe panel and check for a water marks on the motor. If there are any, then the pump & motor assembly has to be replaced.
Start the dishwasher and see how the motor acts.
- The part number for the pump & motor assembly is AP3776341
Here are the break down diagrams for the Kitchen Aid dishwasher Model KUDR24SEBL1
solson
#3 Posted : Friday, January 30, 2009 5:54:48 AM(UTC)
solson
There are no water marks on the motor. The motor doesn't make any sound. I checked the voltage and it showed ok on one wire but there are 4 more that entering the motor and I don't have voltage on any of them. I cannot find the electrical schematic/control drawings. Is it on the back of the machine? How can I verify a bad motor without taking it out?
#4 Posted : Friday, January 30, 2009 6:22:33 AM(UTC)
Guest (4)
Water does not drain completely (Dishwasher Repair)
by g11171 9/17/2012 5:28:01 PM(UTC)
Washer puts water in drum does not turn only hums and water does not drain (Washer Repair)
by vsquared 6/23/2012 7:09:22 PM(UTC)
Washer spins but water does not drain (Washer Repair)
by Ed Marshall 6/7/2011 2:44:45 AM(UTC)
Water does not drain at proper time (Washer Repair)
by Doug109 12/14/2009 3:57:38 PM(UTC)
water does not drain all out on the spin cycle (Washer Repair)
by lavete 9/12/2009 6:06:39 AM(UTC)
water does not drain completely (Refrigerator & Freezer Repair)
by cgmyers 9/7/2009 5:32:07 PM(UTC)
Water does not drain (Washer Repair)
by jtancsi1 7/26/2009 1:32:45 PM(UTC)
by springwash 1/27/2009 5:51:50 PM(UTC)
Water Does Not Drain Unless Extra Spin Cycles (Washer Repair)
by chief455 10/19/2008 9:52:53 AM(UTC)
