Replacement parts for WHIRLPOOL LER7646EQ2 ELECTRIC DRYER | AppliancePartsPros.comSee the attachment for your wiring diagram.
[COLOR="DarkRed"]
i also replaced the two fuses from the element and the one above it[/COLOR]
Not sure I understand the following. The parts breakdown only shows 2 parts near the element.
One is a thermal cut-off (fuse) and the other is a high limit thermostat, so I am not sure what the third device is.
Did you check the replacement parts with a meter before installing them?
Start by checking your power to the unit. The motor and timer run off of 120 volts but the heating coil requires the full 240 volts.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]
Be careful as 240 volts is lethal !!![/COLOR]
Next unplug the unit. Set the timer to mid scale on a heating cycle and check across Timer switch 2. It should be 0 ohms.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
