dave3795
#1 Posted : Friday, November 18, 2011 7:37:13 AM(UTC)
dave3795
approx 2 weeks ago our dryer quit heating. i have tested the thermo fuse and the two fuses on the heating ele (i may have the terms wrong sorry) originally i found bad continuity on the heating element itself and have replaced it, i also replaced the two fuses from the element and the one above it and it still does not heat... i'm at the end of my rope please help!
quick643
#2 Posted : Friday, November 18, 2011 11:53:20 AM(UTC)
quick643
I just had the same problem with my dryer, it's a different model. It ended up being a thermostat. Mine was located on the same housing that the element was in, up above the element on the actual housing. Hope this helps.
#3 Posted : Saturday, November 19, 2011 3:10:52 AM(UTC)
Replacement parts for WHIRLPOOL LER7646EQ2 ELECTRIC DRYER | AppliancePartsPros.com
See the attachment for your wiring diagram.
[COLOR="DarkRed"]
i also replaced the two fuses from the element and the one above it[/COLOR]
Not sure I understand the following. The parts breakdown only shows 2 parts near the element.
One is a thermal cut-off (fuse) and the other is a high limit thermostat, so I am not sure what the third device is.
Did you check the replacement parts with a meter before installing them?
Start by checking your power to the unit. The motor and timer run off of 120 volts but the heating coil requires the full 240 volts.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Next unplug the unit. Set the timer to mid scale on a heating cycle and check across Timer switch 2. It should be 0 ohms.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
File Attachment(s):
LER7646.pdf (316kb) downloaded 20 time(s).
