Heymate
#1 Posted : Tuesday, January 20, 2009 9:45:33 PM(UTC)
Heymate
The little spinner thingy (3Rd level wash spinner kit ) has broken off again!
A year or so ago I had it replaced and it took the guy 2 or 3 trips to figure it out. If I order this part how easy is it to replace? I am assuming the whole machine has to come out ??? I have been putting this off but I feel encouraged by your forum so I will order the part if I can bolster up the courage!! Thanks!
#2 Posted : Thursday, January 22, 2009 12:21:29 PM(UTC)
As you can see on the break down diagram the spinner is attached to the water feed tube with a special pin. Looks like you have to remove the upper dish rack and disassemble the water feed tube from the rear panel.
- The part number for the 3rd level spinner is AP3177952
Heymate
#3 Posted : Sunday, January 25, 2009 9:08:49 PM(UTC)
Heymate
Thanks Gene. Looks like I can do this without pulling the unit out!!
Heymate
#4 Posted : Sunday, January 25, 2009 9:33:48 PM(UTC)
Heymate
A newbie question but am I correct in my assumption that the water feed tube can be removed from the inside without pulling the unit out? Thanks in advance...heymate
#5 Posted : Monday, January 26, 2009 1:29:34 PM(UTC)
Yes, it can. Remove both dish racks first.
Heymate
#6 Posted : Tuesday, January 27, 2009 10:56:51 AM(UTC)
Heymate
Thanks again Gene. I have ordered the part. My last (I hope) newbie question is......What's the trick to removing the top rack. I have studied it but I know there must be a trick......Thankyou so much !!
#7 Posted : Tuesday, January 27, 2009 11:20:35 AM(UTC)
You have to remove the track stop (#20 on the break down diagram) first on each side.
Heymate
#8 Posted : Tuesday, January 27, 2009 3:19:39 PM(UTC)
Heymate
Thanks mate. Many thanks from the British Guy and his Dishwasher.PS...Got the part in ONE day as well. Thanks to all !!!!!!!
#9 Posted : Tuesday, January 27, 2009 5:19:03 PM(UTC)
You are welcome. We are glad you were able to fix it.
