abayomi
#1 Posted : Saturday, January 24, 2009 2:15:51 PM(UTC)
abayomi
Hi There,
We have a Panasonic Microwave that we purchased 4 years ago but NEVER used it until recently because we were doing renos and had to have it vented.
We finally installed it about a year ago and ONLY used the light on the
bottom as it still had not been vented through the attic. About 6 months later the light blew... so I replaced the bulb. Well... that didn't help as it wouldn't turn off so i just removed the bulb.
Then about 5 weeks ago we had it vented and started to use it for heating things up. It was working GREAT!! Three days ago I put a cup of coffee in to re-heat and closed the door. I then pushed 1,3,0 seconds and went to push start and it DIED!!! Never even started.
I phoned around and they said to replace the 18 amp fuse. Once I located one (which was difficult) I popped it in and everything seemed to work just find again over the next day...
We used it about 3 or four times for only a couple of minutes each time and then it died again (no power at all even the
display)! After about 5 minutes... the power came on again. So we tried heating something again... then it worked for just over a minute and near the end of heating 1 1/2 mins it just died. The power returned a short time later and we haven't used it. I noticed after about an hour, even while not using it... once again there was no power!
Not sure if it is related but a couple of weeks ago the door was accidentally slammed quite hard?
I have been told many things like inverter, the door switch, or a problem with a high voltage section?
What is most concerning is we paid such a high price for this microwave and because we never installed it right away... It is not covered by
warranty. Sadly we only used it for 5 weeks and "IF" we have to take it down off the wall about the stove we have to break all the time to get it out. :o)
Please help with any suggestions. I want to have someone come it to look at it but don't want to get the run around.
PLEASE HELP...Any suggestions would be GREATLY APPRECIATED!!
Guy
iamatke
#2 Posted : Tuesday, January 27, 2009 11:46:56 AM(UTC)
iamatke
One of the first things that comes to mind is the electrical supply. You state you were doing renovations so I assme the electrical box for this oven is new. Because of the symptoms you described I would check that box for proper voltage, proper power (amperage), and a proper ground. Fuses blow because they are doing their job, so I would begin by looking at the source.
