2 Pages12>
bgg
#1 Posted : Monday, January 26, 2009 10:41:00 AM(UTC)
bgg
need help in troubleshooting ice and water unit. I turned the water supply off and removed the water inlet valve and checked it for being clogged, everything looked okay, checked water supply line and water pressure is excellent. reinstalled water inlet valve and water supply line, everything worked great for about two hours. Could the water inlet valve be bad and how do I check it.
thanks
bgg
#2 Posted : Tuesday, January 27, 2009 3:26:22 PM(UTC)
Does it work or it stopped? If it is fine now then do not do anything.
bgg
#3 Posted : Wednesday, January 28, 2009 1:43:13 PM(UTC)
bgg
Gene, it stopped working about two hours later.
bgg
#4 Posted : Wednesday, January 28, 2009 2:54:49 PM(UTC)
Check if there is 120VAC to the water dispenser solenoid on the water valve while the dispenser calls for water. Post the results.
bgg
#5 Posted : Thursday, January 29, 2009 1:38:52 PM(UTC)
bgg
while depressing the water depenser I checked the voltage at the water valve and had 67VAC
bgg
#6 Posted : Thursday, January 29, 2009 1:58:21 PM(UTC)
Check the freezer door switch and if there is nothing wrong then the problem most likely a bad micro switch(es) inside the dispenser.
bgg
#7 Posted : Saturday, January 31, 2009 10:16:29 AM(UTC)
bgg
Gene, 120vac at the water inlet valve.
bgg
#8 Posted : Saturday, January 31, 2009 9:24:46 PM(UTC)
Which solenoid? You posted earlier that it was just 67VAC?
bgg
#9 Posted : Sunday, February 1, 2009 7:12:13 PM(UTC)
bgg
at the water inlet valve, where the house water connects into the valve.
#10 Posted : Monday, February 2, 2009 10:42:28 AM(UTC)
Can you tell me which solenoid it was by the picture and why it was different readings?
UserPostedImage
Guest (5)
2 Pages12>
