jayden
#1 Posted : Sunday, November 13, 2011 5:05:38 AM(UTC)
jayden
My dishwasher has a built in water heater that has stopped heating and but I am not getting the error code that shows it. Has anyone had this problem? Does anyone have a service manual or parts breakdown?
barnestk
#2 Posted : Monday, November 14, 2011 3:34:19 PM(UTC)
barnestk
I've had a repairman replace the heater on my LG dishwasher model LDF6810WW and it still does not heat the water. What do we need to check next? :confused:
jayden
#3 Posted : Monday, November 14, 2011 3:38:53 PM(UTC)
jayden
Good question. When it didn't work did he make any suggestion?
barnestk
#4 Posted : Monday, November 14, 2011 5:21:27 PM(UTC)
barnestk
No, not really. I think he realized he made a mistake by replacing the heater in the first place when that wasn't the problem and now he doesn't want to come back and look at it again. :mad:
#5 Posted : Tuesday, November 15, 2011 2:37:56 AM(UTC)
Here is the parts breakdown.
Replacement parts for LG LDF6810BB Dishwasher | AppliancePartsPros.com
Here is a service manual
LDF6810xx LG Dishwasher Repair Service Manual - ApplianceDigest.com
You have to join the site to download the manual but it is free and this is a very good site for manuals and other info for the appliance repair DIYer.
Unplug the unit
First check the resistance of the heater
Should be around 10 ohms.
The wiring diagram does say it is "2 fuse" so I think it has a couple thermal fuses built into it as I cannot find any as separate parts.
If OK then check the wires up to the control board.
It looks like the display shows the water temperature so if this is correct then the thermistor is probably OK.
If it does not look normal or always stays at one reading, I would check the thermistor. Probably a good idea to check it in any case, if it does not read the temperature correctly then it could overheat the heater and blow one of those fuses mentioned earlier.
With luck someone with actual experience with LG will jump in and help out.
Kitchenaid Oven range Superba kgsc308lss0 not heating up (Oven Repair (including Ranges and Cooktops))
by rattty 5/19/2024 6:51:16 PM(UTC)
Glass washer not heating up (Dryer Repair)
by Guest 5/15/2024 7:52:01 AM(UTC)
Gas Oven not heating up (Oven Repair (including Ranges and Cooktops))
by Guest 2/8/2024 7:09:48 PM(UTC)
Still not heating (Dryer Repair)
by artinmartin 10/23/2023 2:36:57 PM(UTC)
new heating element, but still not heating (Dishwasher Repair)
by ScotofBV 7/13/2023 5:47:30 PM(UTC)
How to diagnose Thermador gas oven PG366BS not heating? (Oven Repair (including Ranges and Cooktops))
by Guest 4/12/2023 12:28:01 PM(UTC)
GE Dryer Not Heating - Model: GFDS140ED0WW (Dryer Repair)
by laflair13 3/1/2023 3:14:27 AM(UTC)
Kenmore Elite HE3 not heating and drum not spinning (Dryer Repair)
by Guest 12/23/2022 11:32:17 AM(UTC)
Thermadore PRG304GH oven not heating (Oven Repair (including Ranges and Cooktops))
by Guest 12/15/2022 6:58:50 AM(UTC)
upper oven not heating up to desired temp. it's off by about 50 degrees (Oven Repair (including Ranges and Cooktops))
by Guest 10/14/2022 12:50:23 PM(UTC)
GE Microwave Louder and Not Heating PEB7226SF2SS (Microwave Repair)
by Guest 7/24/2022 9:39:41 AM(UTC)
Samsung Gas Dryer Model DV42H5000GW/A3 not heating (Dryer Repair)
by mikeb22 6/1/2022 9:47:03 AM(UTC)
Whirlpool double wall oven lower not heating (Oven Repair (including Ranges and Cooktops))
by mid 5/23/2022 12:46:49 PM(UTC)
Samsung DV395ETPASU/A1 not heating (Dryer Repair)
by Guest 3/5/2022 5:01:06 PM(UTC)
Bosch washer not heating (Washer Repair)
by Guest 2/6/2022 2:10:46 PM(UTC)
