AppliancePartsPros.com
Appliance Repair Help
Washer Repair
GE Front Loader - Fills but no agitation or spin
Front loader will fill. We hear the door latch engage and disengage. Lock and unlock displays as it should. The door is locked and machine fills with water but it will not agitate or spin in any of the cycles. The clock counts down in all cycles. At the end of each cycle the pump does pump out but there is no agitation or spinning. Any suggestions would be greatly appreciated!
Washer Repair
