Happy Clown
#1 Posted : Tuesday, November 8, 2011 6:26:44 PM(UTC)
Happy Clown
Front loader will fill. We hear the door latch engage and disengage. Lock and unlock displays as it should. The door is locked and machine fills with water but it will not agitate or spin in any of the cycles. The clock counts down in all cycles. At the end of each cycle the pump does pump out but there is no agitation or spinning. Any suggestions would be greatly appreciated!
applianceman
#2 Posted : Wednesday, November 9, 2011 8:42:42 AM(UTC)
applianceman
First make sure the belt is still intact and there is nothing mechanically bad as in the tub spins freely. If there isn’t anything mechanically bad you will need to enter the service mode to view the error codes. The error codes will give you a starting point as to what the problem may be. Here is a few links that will help
GE Front Load Washer Error Codes
GE Front Load Washer Service mode
GE Front Load Washer Won’t Spin Or Tumble
For additional information here is a service manual.
http://www.applianceblog.com/ma.../GE_Frontload_Washer.pdf
Guest (4)
