This puppy works fine except for the "Self Cleaning" function! I finally found what the 'error code' means. Says the door lock is not functioning! Took that mechanism out and it works with "external power".
Question is....Is it the 'control panel'? Circuit board...etc. ? I am not willing to spend that much on a replacement! I'll buy a new oven before that! Everything else works perfectly! Any clues????
tks, ltb
