SILRON
#1 Posted : Monday, January 19, 2009 8:46:38 PM(UTC)
SILRON
hello,i have a 2 years old GE 2 door refrigerator,on one door is the freezer and in the other door is the refrigerator.works good for 7 days then the refrigerator(were the food is) get warm.on the freezer side inside in the back the coil has ice.i need to unplug it and let the ice in the coil melt then connect it and it works with no problems,i have to do this every 7 days.if i do not do this then the freezer will start to get warm slowly as well.
kayakcrzy
#2 Posted : Tuesday, January 20, 2009 3:28:45 AM(UTC)
kayakcrzy
What you have is a defrost problem. What you need to do is take the back panel of the freezer off, and on the bottom of the evaporator coils is the heater. Take the 2 phillip head screws out that hold the heater assembly in place, and then gently pull the wires off of each end, and ohm out the heater, if it is good, then the motherboard which is located behind the refrigerator is bad. If you pull out the refrigerator, on the back wall is a panel held in by three 1/4 inch screws. Take them out, and the board is behind it. This is an easy repair. Tom
SILRON
#3 Posted : Tuesday, January 20, 2009 1:04:24 PM(UTC)
SILRON
thanks for helping,the back panel you stated is outside in the back? when testing for hons what is a positive reading?
thanks
kayakcrzy
#4 Posted : Tuesday, January 20, 2009 4:05:12 PM(UTC)
kayakcrzy
When you check the heaters, if you get any ohm reading it is good. Tom ApplianceEducator.com
mill0866
#5 Posted : Wednesday, September 16, 2009 5:06:02 PM(UTC)
mill0866
I have the same problem - the defrost cycle is not working. I've had a repair man come and diagnose the board, find it is bad, and replace it THREE TIMES! There must be a root cause here, because the chances of three boards going bad within a month is pretty high. Any ideas??
AIMANNY
#6 Posted : Wednesday, September 16, 2009 8:54:32 PM(UTC)
AIMANNY
You may have an elec problem. check outlet
ronamer
#7 Posted : Wednesday, September 16, 2009 11:44:06 PM(UTC)
ronamer
what kind of wiring problem? I know that some houses where I live are old, I mean 1930's old. what can these people do for this? and we have a common occurance of storm related power outages. I live in the Kearny / hayden arizona area. also, due to surges caused by storms, are the power companies responsible for repairs? I know that probably isn't your field, but I had to ask.
