Hambone69
#1 Posted : Sunday, November 6, 2011 2:02:59 PM(UTC)
Hambone69
Freezer works fine, fridge not cooling. Ruled out defrost timer. Trying to figure out if it's defrost thermostat or heater, but cant find diagram to locate them or troubleshooting techniques:(
#2 Posted : Monday, November 7, 2011 3:05:21 AM(UTC)
Replacement parts for WHIRLPOOL ED2FHGXKT00 REFRIGERATOR | AppliancePartsPros.com
[COLOR="DarkRed"]Freezer works fine, fridge not cooling. Ruled out defrost timer. Trying to figure out if it's defrost thermostat or heater, but cant find diagram to locate them or troubleshooting techniques[/COLOR]
Sorry but I do not follow the above.
If the freezer is fine, why do you think it is a defrost problem?
Freezer should be 0 to 5 degrees F.
Are the evaporator coils in the freezer heavily iced/frosted up t the point where the evaporator fan cannot pull air through them. This would be a defrost problem.
Is the evaporator (freezer) fan running it is required to push cold air into the fresh food side?
Is the diffuser/damper (Item 24 in Section 2) open?
Is the louver (Item 4 in Section 2) clear on both sides. this is normally a vent between the compartments and must be clear for proper air flow between tem?
