Freezer works fine, fridge not cooling. Ruled out defrost timer. Trying to figure out if it's defrost thermostat or heater, but cant find diagram to locate them or troubleshooting techniques:(
Here are your parts Replacement parts for WHIRLPOOL ED2FHGXKT00 REFRIGERATOR | AppliancePartsPros.com[COLOR="DarkRed"]Freezer works fine, fridge not cooling. Ruled out defrost timer. Trying to figure out if it's defrost thermostat or heater, but cant find diagram to locate them or troubleshooting techniques[/COLOR] Sorry but I do not follow the above. If the freezer is fine, why do you think it is a defrost problem? Freezer should be 0 to 5 degrees F. Are the evaporator coils in the freezer heavily iced/frosted up t the point where the evaporator fan cannot pull air through them. This would be a defrost problem. Is the evaporator (freezer) fan running it is required to push cold air into the fresh food side? Is the diffuser/damper (Item 24 in Section 2) open? Is the louver (Item 4 in Section 2) clear on both sides. this is normally a vent between the compartments and must be clear for proper air flow between tem? |
THIS FORUM IS DEAD!!!!!!! |
