jimbonnet
#1 Posted : Monday, January 19, 2009 10:35:38 AM(UTC)
jimbonnet
Whirlpool Duet, Gas model. The dryer will no longer leave the "sensing" mode even after 15-20 minutes of running. The dryer does not heat.
Ive checked air flow out out the dryer it is good.
I have not taken off the back cover yet. Is this symptom indicative of a bad thermal cut-out or is this another issue?
Thank you.
Jim
jimbonnet
#2 Posted : Monday, January 19, 2009 12:11:04 PM(UTC)
jimbonnet
Ok, Pulled the back. I have continuity across the thermal cutout.
jimbonnet
#3 Posted : Monday, January 19, 2009 12:12:49 PM(UTC)
jimbonnet
Should the thermistor be open or closed? Mine is reading open.
Drags1998
#4 Posted : Monday, January 19, 2009 12:21:03 PM(UTC)
Drags1998
It should have HIGH RESISTANCE, BUT, not open!!!! If its open,replace it.
#5 Posted : Monday, January 19, 2009 1:23:52 PM(UTC)
Here is a tech sheet that might help
https://www.servicematters.com/d...0Sheet%20-%208558723.pdf
Thermistor should be close to 10Kohms.
Make sure to unplug it when measuring.
jimbonnet
#6 Posted : Wednesday, January 21, 2009 3:24:39 PM(UTC)
jimbonnet
Replaced thermistor.. No help..
Dryer still wont move off of sensing position.. Im tracing back to the control board with the diagnostics sheet provided.. Does someone have a board out they could measure resistance across pins 1 and 2 for the sensor?
Per the document:
Otherwise, measure the resistance
across between pins 1 and 2 of
connector P2 on the machine
control board. If a resistance less
than 1 MΩ is measured (with analog
or digital ohmmeter), inspect the
control board for any debris bridging
these pins. If no debris, replace the
machine control electronics.
Im getting nothing for resistance. Before I make a mistake on a 140$ part I'd like to know for sure if anyone knows. Thanks. Nothing is bridging the pins... Other pin combination's due have resistance..
jimbonnet
#7 Posted : Wednesday, January 21, 2009 6:13:34 PM(UTC)
jimbonnet
ok cleaned up the board now its reading properly.. found a bunch of dust on the backside of the board...
still no joy.
started investigating the burner and the ignitor is cracked on the metal portion of the element.. there's a problem..
I'll replace that and see if I get further along
