lizardqueen
#1 Posted : Saturday, January 17, 2009 9:36:07 AM(UTC)
lizardqueen
bottom oven elements broke and we replaced it .now the brolier and the oven elment wont heat up the control panel works but nothing happens in the oven
kayakcrzy
#2 Posted : Sunday, January 18, 2009 5:35:01 AM(UTC)
kayakcrzy
Did you flip the oven breaker off and on a few times to see if it tripped. I would check the power coming into the oven, where the power goes into the back of the oven. If all is well, replace the control board. Tom
lizardqueen
#3 Posted : Sunday, January 18, 2009 3:02:42 PM(UTC)
lizardqueen
I do not know where the oven breaker is . Is it on the back of the stove? I do no
t have the owners manaual .do you known wher the breaker is located?
kayakcrzy
#4 Posted : Sunday, January 18, 2009 4:35:43 PM(UTC)
kayakcrzy
The oven breaker is where all the power is coming into the house. Tom ApplianceEducator.com
lizardqueen
#5 Posted : Monday, January 19, 2009 5:06:33 AM(UTC)
lizardqueen
afteWe tried the breaker the oven still does,nt work . the stove top works .and always has .Could it possible be the temp probe? thank you
kayakcrzy
#6 Posted : Monday, January 19, 2009 5:34:05 AM(UTC)
kayakcrzy
No, it would not be the temp probe, because the broil element would work, and so would the bake, unless you got a code on the clock control board. It sounds like a clock control problem. Tom
#7 Posted : Monday, January 19, 2009 5:50:08 AM(UTC)
Cannot find any info using the given Model number.
Please double check it.
Also see if you can find a tech sheet / wiring diagram. May be taped under the unit or pot/pans drawer.
Many units have a thermal cutout (thermostat), that cuts power to both elements. Often mounted on the back wall of the oven (outside)
kayakcrzy
#8 Posted : Monday, January 19, 2009 1:10:40 PM(UTC)
kayakcrzy
Its probably a fes353??? or a FES355??? Tom ApplianceEducator.com
