annette74
#1 Posted : Wednesday, November 2, 2011 4:47:09 AM(UTC)
annette74
Washer was overloaded, clothes were completely removed water remained in the basin. Then I restarted the cycle from the begining goes completely thru the cycle but on final spin, it spins but water does not drain and after a few min of spinning the burning rubber smell occurs.:confused:
sidfink43
#2 Posted : Thursday, November 3, 2011 5:35:32 PM(UTC)
sidfink43
If you are saying it drains and spins ok after the wash cycle, but not after the rinse cycle then this is somewhat of a mystery.
I would open it up and check the pump and internal hoses for a blockage or obstruction. Given that you overloaded it that is the first place to check.
annette74
#3 Posted : Thursday, November 3, 2011 5:43:15 PM(UTC)
annette74
You were right took it apart yesterday, removed both hoses and found a sock in one.
sidfink43
#4 Posted : Thursday, November 3, 2011 5:53:50 PM(UTC)
sidfink43
Great, nice going and glad you got it fixed. Thanks for the update and good luck going forward.
