Travis7009
#1 Posted : Friday, January 16, 2009 4:15:37 PM(UTC)
Travis7009
I recently tried some dryer repair. I replaced the Thermal fuse, the fixed thermostat and the cycling thermostat. Now the dryer is running but there is a constant glow coming from the heating element. I have never noticed it before. Should it glow all the time? If not how can I fix the problem? Please help
#2 Posted : Friday, January 16, 2009 5:12:00 PM(UTC)
Here is your parts breakdown
Model REX6634PQ0
And the wiring diagram
https://www.servicematters.com/d...0Sheet%20-%208528187.pdf
Put the unit in Air Only cycle if heater still glowing then you probably have a grounded element re: the heating coil is touching the case.
Travis7009
#3 Posted : Saturday, January 17, 2009 7:53:49 AM(UTC)
Travis7009
It looks like that is exactly what it is Thanks
Travis7009
#4 Posted : Saturday, January 17, 2009 11:33:32 AM(UTC)
Travis7009
I replaced the heating element but now it won't heat up at all. What else could be wrong? Is it a bad thermal cutoff or is it something else
