notfrozen
#1 Posted : Wednesday, January 14, 2009 9:21:38 AM(UTC)
notfrozen
I just installed a new ice mold because its surface was chipping - no other problems at all. Now it cycles to early and pushes out shells of ice with water. The water collects inthe storage bin. Any way to calibrate this thingG
#2 Posted : Thursday, January 15, 2009 8:20:50 PM(UTC)
Most likely you installed the thermostat improperly when you replaced the mold & heater assembly. You have to use the alumilastic cement, part number AP3103415, to install the thermostat on the new mold & heater assembly.
kayakcrzy
#3 Posted : Friday, January 16, 2009 3:04:55 PM(UTC)
kayakcrzy
It could be the water valve. Tom
