shakeymac
#1 Posted : Thursday, January 15, 2009 5:32:13 PM(UTC)
shakeymac
had the hot water heater question can someone plz help
libertyappl
#2 Posted : Thursday, January 15, 2009 5:36:27 PM(UTC)
libertyappl
Give a complete description of the problem.
Nat
shakeymac
#3 Posted : Thursday, January 15, 2009 5:41:45 PM(UTC)
shakeymac
k heater (electric) was replaced because it leaked the one i replaced it with was one i had around for a while. prob is i hooked up and not working. multi meter read 114v on top element 0 on bottom ellement woundering also i have black n red wire from my tank and white and black from power box im lost can u plz help?
libertyappl
#4 Posted : Thursday, January 15, 2009 5:57:19 PM(UTC)
libertyappl
What's the voltage from the black & white wires? It should be right at 220-240 Volts.
shakeymac
#5 Posted : Thursday, January 15, 2009 6:01:03 PM(UTC)
shakeymac
if i put probe on each end it reads 228 volts more i think about it im thinking it is probably the thermostat unit ??? i dont want any more cold showers lol. is there a way to test thermostat can i email u?
libertyappl
#6 Posted : Thursday, January 15, 2009 6:15:19 PM(UTC)
libertyappl
Feel free to email me if you like.
ernesto1959
#7 Posted : Thursday, January 15, 2009 6:22:22 PM(UTC)
ernesto1959
Put your meter in continuity or ohms ( U Inverted ) and when the meter leads are separeted reading must be Infinity or open line (OL) or zero. CHeck your Heater element , must give you a number, but no (OL), that will mean the element may be ok, check the termostat it must have two wires put the meter leads one in each wire ...must give you a # , but not (OL) if it fail move the setting all the way to max . temp. check again . also it must have a limit control 2 Wires ...do the same one meter lead to each wire , that is the trouble shoot for a failed part. the one that is open is the one that is not allowing power to pass .good luck.......some limits are manual reset and have a small push bottom.that closes the swich and allow the power to continue its path.
ernesto1959
#8 Posted: : Thursday, January 15, 2009 6:29:20 PM(UTC)
ernesto1959
see how to check continuity in other posts....each part that need to be checked ...need to isolated....
Can anyone help me solve this problem? (Refrigerator & Freezer Repair)
by RDele 3/12/2009 1:43:59 PM(UTC)
Water and ice won't dispense from GE fridge. Can anyone help? (Refrigerator & Freezer Repair)
by Steph1079 3/6/2009 5:37:50 AM(UTC)
