have maytag refiregerator model MSD2641KEU SERIAL # 50095244JR BOUGHT IN 2007 never any problem this first time it has broken . PROBLEM I HAVE IS REFIRGERATOR has STOP BLOWING COLD NO COLD AIR COMES OUT I HAVE THE SIDE BY SIDE REFIGERATOR THE FREEZER WORKS FINE JUST REFIREGERATOR SIDE STOP WORKING I NEED TO KNOW WHAT PART TO REPLACE . i have replace so far this part adc the part in white box located circuit board proble still there. after i melt freezer side all is good until gets frozen than i have no air flow going to refrigerator side . below is the part i replaced :confused: :confused: :confused: thank you for the help Board, Adapt Defrost Part Number: AP4078743
Here are your parts Replacement parts for MAYTAG MSD2641KEU REF - SXS/I&W | AppliancePartsPros.comBefore you replaced the ADC did you try to force a defrost cycle and did the defrost heater come on? First remove the evaporator cover in the freezer so you can see the coils. Do not let them de-ice. If they are heavily iced/frosted over you have a defrost problem. If we assume that the new ADC is OK. Unplug the unit. Remove the wire for one side of the heating element (Item 7 in Section 6) from the wiring and measure it for continuity, usually around 20 ohms or so. If the heater is OK Remove one wire to the defrost thermostat (Item 3 in Section 6) and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK. If both the above are OK then odds are the new ADC is toast or you have a bad connection somewhere. If you do not own a meter, I would suggest you purchase a one. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long. If it saves ordering one unnecessary part it has paid for itself and you end up owning a useful tool. Most places will not let you return electrical parts so if you order it, you own it. A couple things to watch when measuring ohms and continuity 1. Always remove power from the machine otherwise you could blow your meter. 2. Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path. 3. When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale's dynamic range. 4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset. There is a good STICKY at the start of this forum about it's use. |
THIS FORUM IS DEAD!!!!!!! |
ok i have tested the heater it messures 29 ohms the thermost frozen was meshuring 5 ohms so is bad thermostat ? also i melt all the ice hair dryer and it starts to work but ice builds very fast on evaporator that is normal ? also can i feel the heater get hot is i touch with hand i dont feel it hot ? Originally Posted by: volvo ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) have maytag refiregerator model MSD2641KEU SERIAL # 50095244JR BOUGHT IN 2007 never any problem this first time it has broken . PROBLEM I HAVE IS REFIRGERATOR has STOP BLOWING COLD NO COLD AIR COMES OUT I HAVE THE SIDE BY SIDE REFIGERATOR THE FREEZER WORKS FINE JUST REFIREGERATOR SIDE STOP WORKING I NEED TO KNOW WHAT PART TO REPLACE . i have replace so far this part adc the part in white box located circuit board proble still there. after i melt freezer side all is good until gets frozen than i have no air flow going to refrigerator side . below is the part i replaced :confused: :confused: :confused: thank you for the help Board, Adapt Defrost Part Number: AP4078743
[COLOR="DarkRed"]ok i have tested the heater it messures 29 ohms the thermost frozen was meshuring 5 ohms so is bad thermostat ? [/COLOR] Yes the defrost thermostat should be 0 ohms. 5 ohms would indicate a bad thermostat.
[COLOR="DarkRed"]also i melt all the ice hair dryer and it starts to work but ice builds very fast on evaporator that is normal ?[/COLOR] Yes. Not ice right away but frost that eventually turns to ice. Any moisture in the freeze and fresh food sections will condense onto the evaporator coils. Sometimes if this is excessive it indicates that the door seals are not sealing correctly. To check for this take a 2 inch strip of paper and place it between the door seal and the fridge's body. Then pull it out to see if the door is sealing. It it pulls out with no resistance then you have a sealing problem. You will have to work your way around the door doing it every 6 inches or so.
[COLOR="DarkRed"] also can i feel the heater get hot is i touch with hand i dont feel it hot ?[/COLOR] Sorry you lost me here. |
thank you for you help so when i get new thermostat do i solder the wires or ? Originally Posted by: denman ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) ok i have tested the heater it messures 29 ohms the thermost frozen was meshuring 5 ohms so is bad thermostat ? Yes the defrost thermostat should be 0 ohms. 5 ohms would indicate a bad thermostat.
also i melt all the ice hair dryer and it starts to work but ice builds very fast on evaporator that is normal ? Yes. Not ice right away but frost that eventually turns to ice. Any moisture in the freeze and fresh food sections will condense onto the evaporator coils. Sometimes if this is excessive it indicates that the door seals are not sealing correctly. To check for this take a 2 inch strip of paper and place it between the door seal and the fridge's body. Then pull it out to see if the door is sealing. It it pulls out with no resistance then you have a sealing problem. You will have to work your way around the door doing it every 6 inches or so.
also can i feel the heater get hot is i touch with hand i dont feel it hot ? Sorry you lost me here.
You could solder it in but it is easier to use a couple wire nuts. Then zip tie them up so that they face down so water will not get into them.
Some folks like to seal them with some sealant as an extra precaution. . If you do this I would recommend you force a defrost cycle just to be sure everything is OK before doing this. |
ok i have replaced the parts and is fixed but small problem i made my self the bulb was staying close to the frame of refrigerator and melted the plastick thru now my question what do i use to plug the hole i try silicon but i dont if that is good is there like any poxy glue i hope you have some advice for this :) but thank you for the help Originally Posted by: denman ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) You could solder it in but it is easier to use a couple wire nuts. Then zip tie them up so that they face down so water will not get into them.
There is foil backed tape that you can get a most hardware stores. It is used to repair fridge liners etc. I would use a piece of that to cover the hole.
The foil then will reflect the heat away from the liner. |
THANK YOU FOR ADVICE CAN YOU POINT ME ONLINE WHAT TAPE TO BUY IM SORRY I WAS LOOKING AT STORES BUT THEY SALE ME DUCK TAPES AND SOME OTHER TAPES I DONT THINK IS THAT IF YOU CAN PLEASE SEND ME LINK WHAT TO BUY ONLINE I WILL ORDER IT THANK YOU AGAIN Originally Posted by: denman ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) There is foil backed tape that you can get a most hardware stores. It is used to repair fridge liners etc. I would use a piece of that to cover the hole.
