volvo
#1 Posted : Friday, October 14, 2011 9:32:08 PM(UTC)
volvo
have maytag refiregerator model MSD2641KEU SERIAL # 50095244JR BOUGHT IN 2007 never any problem this first time it has broken . PROBLEM I HAVE IS REFIRGERATOR has STOP BLOWING COLD NO COLD AIR COMES OUT I HAVE THE SIDE BY SIDE REFIGERATOR THE FREEZER WORKS FINE JUST REFIREGERATOR SIDE STOP WORKING I NEED TO KNOW WHAT PART TO REPLACE . i have replace so far this part adc the part in white box located circuit board proble still there. after i melt freezer side all is good until gets frozen than i have no air flow going to refrigerator side . below is the part i replaced :confused: :confused: :confused: thank you for the help
Board, Adapt Defrost
Part Number: AP4078743
#2 Posted : Saturday, October 15, 2011 3:29:10 AM(UTC)
Replacement parts for MAYTAG MSD2641KEU REF - SXS/I&W | AppliancePartsPros.com
Before you replaced the ADC did you try to force a defrost cycle and did the defrost heater come on?
First remove the evaporator cover in the freezer so you can see the coils.
Do not let them de-ice.
If they are heavily iced/frosted over you have a defrost problem.
If we assume that the new ADC is OK.
Unplug the unit.
Remove the wire for one side of the heating element (Item 7 in Section 6) from the wiring and measure it for continuity, usually around 20 ohms or so.
If the heater is OK
Remove one wire to the defrost thermostat (Item 3 in Section 6) and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are the new ADC is toast or you have a bad connection somewhere.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
volvo
#3 Posted : Saturday, October 15, 2011 2:37:11 PM(UTC)
volvo
ok i have tested the heater it messures 29 ohms the thermost frozen was meshuring 5 ohms so is bad thermostat ? also i melt all the ice hair dryer and it starts to work but ice builds very fast on evaporator that is normal ? also can i feel the heater get hot is i touch with hand i dont feel it hot ?
#4 Posted : Sunday, October 16, 2011 5:23:42 AM(UTC)
[COLOR="DarkRed"]ok i have tested the heater it messures 29 ohms the thermost frozen was meshuring 5 ohms so is bad thermostat ? [/COLOR]
Yes the defrost thermostat should be 0 ohms.
5 ohms would indicate a bad thermostat.
[COLOR="DarkRed"]also i melt all the ice hair dryer and it starts to work but ice builds very fast on evaporator that is normal ?[/COLOR]
Yes.
Not ice right away but frost that eventually turns to ice.
Any moisture in the freeze and fresh food sections will condense onto the evaporator coils.
Sometimes if this is excessive it indicates that the door seals are not sealing correctly.
To check for this take a 2 inch strip of paper and place it between the door seal and the fridge's body. Then pull it out to see if the door is sealing. It it pulls out with no resistance then you have a sealing problem. You will have to work your way around the door doing it every 6 inches or so.
[COLOR="DarkRed"] also can i feel the heater get hot is i touch with hand i dont feel it hot ?[/COLOR]
Sorry you lost me here.
volvo
#5 Posted : Monday, October 17, 2011 7:00:04 PM(UTC)
volvo
thank you for you help so when i get new thermostat do i solder the wires or ?
Yes.
#6 Posted : Tuesday, October 18, 2011 12:53:10 AM(UTC)
You could solder it in but it is easier to use a couple wire nuts.
Then zip tie them up so that they face down so water will not get into them.
Some folks like to seal them with some sealant as an extra precaution. .
If you do this I would recommend you force a defrost cycle just to be sure everything is OK before doing this.
volvo
#7 Posted : Saturday, October 22, 2011 4:14:50 PM(UTC)
volvo
ok i have replaced the parts and is fixed but small problem i made my self the bulb was staying close to the frame of refrigerator and melted the plastick thru now my question what do i use to plug the hole i try silicon but i dont if that is good is there like any poxy glue i hope you have some advice for this :) but thank you for the help
#8 Posted : Sunday, October 23, 2011 3:58:17 AM(UTC)
There is foil backed tape that you can get a most hardware stores.
It is used to repair fridge liners etc.
I would use a piece of that to cover the hole.
The foil then will reflect the heat away from the liner.
volvo
#9 Posted : Sunday, October 23, 2011 3:46:24 PM(UTC)
volvo
THANK YOU FOR ADVICE CAN YOU POINT ME ONLINE WHAT TAPE TO BUY IM SORRY I WAS LOOKING AT STORES BUT THEY SALE ME DUCK TAPES AND SOME OTHER TAPES I DONT THINK IS THAT IF YOU CAN PLEASE SEND ME LINK WHAT TO BUY ONLINE I WILL ORDER IT THANK YOU AGAIN
#10 Posted : Monday, October 24, 2011 4:09:53 AM(UTC)
I think this is the stuff.
Ace® Industrial Strength Metal Repair Tape - Duct & Cloth Tape - Ace Hardware
They do use it to seal ducts so any store that sells heating ducting should have it.
The pros do not use the fiber type of duct tape as it does not seal the good and does not last very long.
maytag evaporator gets frozen with ice (Refrigerator & Freezer Repair)
by volvo 10/14/2011 9:30:22 PM(UTC)
by volvo 10/14/2011 9:27:25 PM(UTC)
by volvo 10/14/2011 9:26:39 PM(UTC)
