Bucky
#1 Posted : Monday, January 12, 2009 5:19:09 PM(UTC)
Bucky
First, oven stopped working. Found a wire that had been bared (maybe by mouse), and the oven (bottom) ignitor was open. Replaced ignitor, now "clean" light flashes, and oven will not try to light. Terminals at back of thermostat do not change voltage when turning thermostat to bake. Funny thing is that it did read voltage when I was diagnosing the ignitor. Did I do something?
Bucky
#2 Posted : Tuesday, January 13, 2009 2:54:44 AM(UTC)
Bucky
Anyone? Could really use the help. More info needed?
#3 Posted : Tuesday, January 13, 2009 7:28:10 PM(UTC)
Originally Posted by: Bucky Go to Quoted Post
...Found a wire that had been bared (maybe by mouse)...
What did you do with that wire?
Bucky
#4 Posted : Wednesday, January 14, 2009 3:11:30 AM(UTC)
Bucky
It was one of the leads for the igniter. So I transfered it to the new igniter and taped it up. It had continuity through it, so I don't think there were any breaks.
#5 Posted : Wednesday, January 14, 2009 11:09:53 AM(UTC)
Check the position of the door lock. Check the door lock switch and the wires.
Here are the break down diagrams for the GE range Model LGB356BEA1AD
Bucky
#6 Posted : Wednesday, January 14, 2009 3:04:33 PM(UTC)
Bucky
That was it. Some insulation had migrated (maybe by mouse) around the switch. I poked around the switch, and bingo! I need to get in there and clean up the insulation better, but can't see best how to do it. I tried taking the front knob face off, but the three screws that I thought held it on didn't release it. Almost done now! At least we can bake dinner tonight!
Bucky
#7 Posted : Wednesday, January 14, 2009 3:05:03 PM(UTC)
Bucky
Oh, and thank you!!!
#8 Posted : Wednesday, January 14, 2009 6:49:35 PM(UTC)
You are welcome.
