baymvay
#1 Posted : Thursday, January 8, 2009 3:33:26 PM(UTC)
baymvay
Hi. My GE fridge (Model PSS25MGNA WW) is not doing well these days. First of all, things freeze up in the fridge even when I set the temp at the warmest setting. The Turbocool cool light is always on. A few years ago, I replaced the defrost thermostat and temperature sensor in the freezer because the freezer was not defrosting. Since then the fridge had been working fine. Over the last few months or so, I have had to raise the temp (i.e. make it LESS cool, where is 0 is cool, and 9 is the coldest setting) in the freezer to 2 and the fridge to 3 because things were freezing up in the fridge. The green indicator light for the Turbocool in the fridge is lit up all of the time no matter what I do (press button, hold button, etc). I am under the impression that this could be a problem with the touchpad, the control board, or the main control board on the back of the unit. I'd greatly appreciate your help... Sincerely, Jason
thumbrfg
#2 Posted : Friday, January 9, 2009 2:28:22 AM(UTC)
thumbrfg
Man
United States
I had the same experience on the same exact model.
In my case, I found the the Fresh Food Damper Door broke off the motor assembly.
You may want to check this.
If this is your case, you will need a Kit....Part No: WR49X10091
baymvay
#3 Posted : Friday, January 9, 2009 6:04:41 AM(UTC)
baymvay
How do you determine if this damper is the problem, and that it is not one of the control boards?
thumbrfg
#4 Posted : Sunday, January 11, 2009 6:23:24 AM(UTC)
thumbrfg
Man
United States
The Air Chute Asm in the top of the refrigerator section was removed and a visual observation was made. In my case, the Damper Door broke off the motor mechanism.
baymvay
#5 Posted : Sunday, January 11, 2009 5:06:40 PM(UTC)
baymvay
Thanks for the input. I checked the air chute, and the door was in deed broken from the motor mechanism...I took everything out, and carefull fixed the broken plastic door with some super glue...I put it all back together and the mechanism is working properly, but the TurboCool light is still lit up all of the time...When I press the turbocool button, the light gets brighter, the door closes, and the fan turns on...
sanjayd
#6 Posted : Sunday, October 2, 2011 5:04:00 PM(UTC)
sanjayd
So how do you fix the problem?
JFC2290VEM Jenn Air Fridge too cold (Refrigerator & Freezer Repair)
by investwisely 1/23/2024 5:40:51 PM(UTC)
GE Profile Arctica Fridge too cold (won't set above 28F) (Refrigerator & Freezer Repair)
by Rocket Rider 2/20/2021 1:47:57 PM(UTC)
Kitchenaid fridge too cold. Freezer OK. (Refrigerator & Freezer Repair)
by Dgclarkson 1/23/2021 1:39:46 PM(UTC)
Freezer Defrost Cycle Too Long, Fridge Too Cold (Refrigerator & Freezer Repair)
by mruzga 6/25/2020 3:55:15 PM(UTC)
Whirlpool freezer and fridge too cold (Refrigerator & Freezer Repair)
by 1alembic 3/4/2018 8:16:58 PM(UTC)
Whirlpool side by side fridge too cold (Refrigerator & Freezer Repair)
by whiskysniper 2/28/2018 5:52:34 AM(UTC)
Freezer too warm, fridge too cold (Refrigerator & Freezer Repair)
by Prepper 1/28/2018 10:10:48 AM(UTC)
Freezer Fine -Refridge too cold (Refrigerator & Freezer Repair)
by derfrewol 8/4/2014 11:58:03 AM(UTC)
Monogram running constantly, fridge too cold (Refrigerator & Freezer Repair)
by dukebravo 5/30/2014 4:54:03 AM(UTC)
freezer not freezing, fridge too cold (Refrigerator & Freezer Repair)
by donnyt 12/17/2013 1:59:29 PM(UTC)
fridge too cold, freezer ok (Refrigerator & Freezer Repair)
by jmlund 11/15/2013 10:41:23 AM(UTC)
GE GTS Fridge too Cold (Refrigerator & Freezer Repair)
by ratm 2/18/2013 5:47:09 AM(UTC)
Fridgidaire Fridge too cold, freezer appears OK (Refrigerator & Freezer Repair)
by FredK35 2/4/2013 3:19:52 AM(UTC)
fridge too cold on fridge side (Refrigerator & Freezer Repair)
by bigden123 1/13/2013 3:42:52 PM(UTC)
Fridge Too Cold, Water dispenser inoperative (Refrigerator & Freezer Repair)
by IXLR8 12/6/2012 12:55:31 PM(UTC)
